I am new to this but I have used over the last few weeks DVD2SVCD with advanced settings to create back-ups of DVD's. I have had mixed results. Some work well, and sometimes I get some type of error somewhere along the line. My question though is, I just ripped attack of the clones and reencoded it using the Super Newbie guide for DVD to DVDR. AFter I was done, I got the movie down to about 3.7 GB's which would be fine to fit on a DVD-R. I went to import assets into Maestro as usual, but after I imported the MPV file, I went to import the .AC3 file and Maestro gave me an error that said ..."Cannot locate a frame sync word at an expected byte offset. Data might be corrupted. Then there was this error code. (OXC 1070042) Could someone please help me and tell me what may of caused this error and how I can fix it so I can prevent it in the future? Thanks in advance
Results 1 to 1 of 1
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
Importing multi-tracked audio (.ac3) into Sony Vegas Pro 9.0
By Thunderhead2772 in forum EditingReplies: 0Last Post: 28th Aug 2010, 18:10 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Importing files with AC3 sound into editing software
By jeanpave in forum Video ConversionReplies: 10Last Post: 21st Apr 2010, 01:55 -
Importing AC3 into Premiere Pro ?
By Zetti in forum EditingReplies: 14Last Post: 23rd Jan 2009, 00:45
