How would i go about putting a dat file onto a vcd, i'm stuck on this one?
I'd be greatfull of any helpfull replies on this matter![]()
You probably should convert your DAT file back to standard MPEG first: VCDGear or CDXA2MPEG ( http://www.michaeltam.com/vcdimager_tools_gui.html ) though it may not be necessary.
Just use your DAT/MPEG file as the source file to create a new VCD. For example, with VCDEasy or Nero.
Regards.Michael Tam
w: Morsels of Evidence -
I just rename the extension from .dat to .mpg, then convert to vcd using tmpeg or burn to vcd with nero. I haven't had a problem yet with this method.
I'm Speed Racer and I Like to Drive Fast!
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19
