If it's possible, i would like to know how.
Thanks.
I don't know too much, but I believe they sell special version for Premiere. Did you try their web ?
From web...
Plug and Play Compatibility
Adobe® Premiere®
Pinnacle Edition
Avid® MCXpress, Xpress, Composer, Symphony
Sony Xpri
inync® Speed Razor
Hollywood FX certainly works with Premiere 6 and 6.5 - you just have to install it and it will scan to find out where Premiere is installed. If it is an older version, you may have to point it in the right direction if you have 6.5 installed.
A caution - after installation, and a reboot, you will be asked for the installation CD I.D. number and it will generate a unique number based upon your computer characteristics. This new number has to be registered at Pinnacle who will then generate a Key-code which has to be entered in order to fully unlock the programme and remove the demo time and other restrictions.
It is a very useful programme which can produce some out of the ordinary transitions, however, it is processor, RAM, and video card intensive if you want to see the results of your work in real time.
Regards. -
thanks man... i think it's not working because i instaled premiere after the HFX install... i'll reinstall it now and see!
what transitions to use and when ?
By codemaster in forum EditingReplies: 12Last Post: 22nd Mar 2011, 14:03 -
transitions hard to add on multiple clips in premiere
By codemaster in forum EditingReplies: 11Last Post: 7th Jan 2011, 11:34 -
how can i make transitions
By wan2no in forum Authoring (DVD)Replies: 3Last Post: 14th Jun 2008, 18:33 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 17:02 -
Pinnacle Studio Plus Titanium 10.5 versus Adobe Premiere Elements
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2007, 16:48
