  1. Hey everyone -
    I'm having a problem with my captured videos. I capture a whole movie, and I go to play it back, and the audio and video aren't in sync with eachother. I'm using the Dazzle digital video creator. Anyone have any idea why this isn't working? I keep my dazzle near a central air vent, so I would have to think that its not because its too hot. I don't know whats going on, and if someone could help me out here, it would be a lot of help to me. Thanks in advance.
    -MQ
    May 2001
    London, UK - Bonn, Germany
    Are you using the DVC or the DVC II?
    If you are using the DVC I have often heard of this problem, something about the USB.
    I would suggest you try this forum and also maybe do a search on the problem "audio sync"
    http://stop.at/dazzle2
  3. I'm using the original DVC 1 (Parallel Port Version)
    May 2001
    To be honest with you, I didn't even know there was a parallel version of the DVC. Obviously you know that the parallel port as in input/output device is very very slow. If you just recently bought this device I would try and take it back. You could reduce your capture frame size and frame rate, but I think in the long run you won't be happy.
    I would still urge you to leave a "help wanted" notice in the dazzle forum, as most people with dazzle problems go there for help.
