  1. most of my files play upside down in wmp-- i create clips that play fine on another machine--inverted on mine--any help is thanked in advance...
    newest version of wmp----7.?
    Jul 2002
    Erie, PA United States
    It might help if you posted what graphics card you have. I have a hunch but I'm not going to comment at the moment till I know more.
    Warning! I'm baaaaaaaaack
  3. i have an hp 4563z pavilion running win98se......
    i beleive its a riptide 11mb agp card
    Jul 2002
    I got your PM and did a search on that card and the closest thing I came across was a reference to a riptide PCI audio card. Are you sure this the name of your graphics card? One thing you might want to try is download the Nimo Codec Pack: http://www.btinternet.com/~nimosiro/ and install the Bicubic Resizer Filter. Since I'm flying in dark here this is my best guess.
  5. I have nimo installed etc............. all the rest of wha u said.........already got it.......
    Jul 2002
    Ok next question. Did this problem occur after you installed the Nimo codec pack or was it already present?
  7. yes -i beleive the video card u mentioned is it (pci) riptide audio--
    i think the problem arose after the nimo pack--(i think.......)
