  1. Hello guys. I have been searching for this, but didn't find it.
    I'm using DVDSVCD and just did a svcd; it looks great, but subs didn't play in my standalone. But anyway, I just wanted to ask if it's possible to create a VCD of 2cds with the files created from the SVCD project.
    The SVCD made 3 cds (mpg) and also i have a bunch of files like: .cue, .bin, .mpv, .avs, .ecl, .d2s, .vaf, .mp2.
    I have CEE and TMPGEnc; so If it's possible to use some of those files to do the VCD, and you could tell me how I really would apreciate it. Is there any link to see a tutorial?
    Also I was surprised that everything went fine without installing the ASPI drivers, I have windows XP pro/ P45.53 GHz/ 512MB/ 128 MB Video.
    Thanks.
    This is the log file from DVD2SVCD:
    WNASPI32.DLL 0.0.0.0
    - DVD to SVCD Conversion
    - DVD2SVCD ver. 1.1.0 build 1a
    Initializing
    Initializing finished.
    - Analyzing subtitles
    Subtitle found: StreamID: 0x20 Language: English
    Executing subtitle selection/verification.
    Subtitle selection/verification accepted.
    1 subtitle streams selected.
    Saving Subtitles ini file
    -- DVD2AVI
    Creating DVD2AVI INI file:
    - C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
    Variable settings:
    iDCT_Algorithm: 32-bit SSE MMX
    Executing DVD2AVI.
    Executing DVD2AVI. Commandline:
    "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Program Files\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[C:\Movie\vts_01_1.vob,C:\Movie\vts_01_2.vob,C:\Mov ie\vts_01_3.vob,C:\Movie\vts_01_4.vob,C:\Movie\vts _01_5.vob,C:\Movie\vts_01_6.vob,C:\Movie\vts_01_7. vob]
    Analyzing DVD2AVI Project file
    Force Film activated!
    Framerate: 23976
    DVD2AVI processing done.
    - Free on drive C: 63222.20 mb
    - Extracting the subtitles.
    Subtitle extraction finished. Extracted these subtitles:
    SVCD Stream no: 1 Language: English Num. of subs: 1384
    - Free on drive C: 63208.84 mb
    - AUDIO Extraction
    Found AC3 stream id: 0x80
    Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
    Audio1 delay: 0 ms
    Audio extraction finished.
    - Free on drive C: 62637.35 mb
    - AUDIO conversion
    Encoding Audio. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
    Executing BeSweet. Commandline:
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.lo g" ) -azid( -L -3db -c normal -s surround -g max ) -2lame( -e -b 224 -m s )
    Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
    Audio conversion finished.
    - Free on drive C: 62351.60 mb
    - Converting Pictures
    Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
    Finished converting pictures
    - Free on drive C: 62350.80 mb
    - Video Encoding using Cinema Craft
    Executing Cinema Craft Encoder.
    StreamSectors: 2497628364
    AudioSectors: 303925748
    VideoPAPO: 33981624
    ScanOffsetBytes: 307872
    SeqAligningBytes: 19566976
    DVDBytes: 0
    VideoEndHeader: 12
    SubtitleSectors: 5658940
    EmptySectors: 238.00
    PictureSectors: 600.00
    PureMPEGStream: 2134187192.00
    Seconds: 10709.70
    CalcMPEGStream: 2134187192.00
    Frames: 256560
    CDSize: 800.00
    Number of CDs: 3
    Cut point 792.00
    Variable Settings:
    Frames: 256560
    Anti Noise Filter: Off
    Passes: 4
    Image Quality: 17
    VAF file creation: On
    Video Encoding Mode: Multipass VBR
    Min. bitrate: 300
    Max. bitrate: 2530
    Avg. Bitrate: 1594
    Aspect Ratio: 16:9 (borders added, encoded as 4:3)
    ---AVS Begin---
    LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec .dll")
    mpeg2source("C:\PROGRA~1\DVD2SVCD\Movie\DVD2AV~1.D 2V")
    BicubicResize(480,360,0.0,0.6)
    AddBorders(0,60,0,60)
    ResampleAudio(44100)
    ----AVS End----
    Closing program
    CCE Max Speed: 1.920
    Video Encoding finished.
    - Free on drive C: 60274.27 mb
    - Video Pulldown
    Executing Pulldown. Commandline:
    "C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "C:\Program Files\DVD2SVCD\Movie\Encoded_Video_CCE_NTSC.mpv" "C:\Program Files\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC.m pv"
    Video pulldown finished.
    - Free on drive C: 58240.93 mb
    - Converting Pictures from ES to PS
    Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
    - Free on drive C: 58240.92 mb
    Executing RunbbMPEG. Commandline:
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\ChangeCDPicture.bmp.mpg"
    - Free on drive C: 58240.88 mb
    - Multiplexing and cutting
    Offset in Seconds: 2
    Executing bbMPEG.
    Variable Settings:
    Movie offset: 2 seconds
    Cut point: 792 mb
    "C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
    Length of C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
    3614 Seconds
    Offset in Seconds: 3616
    Executing bbMPEG.
    Variable Settings:
    Cut point: 792 mb
    3609 Seconds
    Offset in Seconds: 7225
    Executing bbMPEG.
    Variable Settings:
    Cut point: 792 mb
    Multiplexing and cutting finished.
    - Free on drive C: 55864.82 mb
    - Determining length of audio
    Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
    3616.272 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
    Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
    3611.688 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
    Analyzing: C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
    3475.440 seconds C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
    Analyzing finished.
    Saving Subtitle Timecodes.
    SVCD subtitles.
    3616
    Length of C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
    3611
    Length of C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
    3475
    - Free on drive C: 55863.77 mb
    - Multiplexing SVCD Subtitles
    Muxing English subtitles, CD 1
    Executing SubMux. Commandline:
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg" -l "C:\Program Files\DVD2SVCD\Movie\Subs\SubLog1.txt" -s0 "C:\Program Files\DVD2SVCD\Movie\Subs\en1-1.sub" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File-subbed00.mpg"
    Muxing English subtitles, CD 2
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg" -l "C:\Program Files\DVD2SVCD\Movie\Subs\SubLog2.txt" -s0 "C:\Program Files\DVD2SVCD\Movie\Subs\en1-2.sub" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File-subbed01.mpg"
    Muxing English subtitles, CD 3
    "C:\Program Files\DVD2SVCD\WinSubMux\WinSubMux.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg" -l "C:\Program Files\DVD2SVCD\Movie\Subs\SubLog3.txt" -s0 "C:\Program Files\DVD2SVCD\Movie\Subs\en1-3.sub" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File-subbed02.mpg"
    Muxing subtitles finished
    - Free on drive C: 53479.49 mb
    - Creating CD-Images using VCDXBuild
    - No. of chapters to create: 15
    CD image #1: CD_Image_File_CD1.bin
    Executing VCDXBuild. Commandline:
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD1 .cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD1 .bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~1.XML"
    - Free on drive C: 52672.82 mb
    CD image #2: CD_Image_File_CD2.bin
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD2 .cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD2 .bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~2.XML"
    - Free on drive C: 51867.30 mb
    - No. of chapters to create: 13
    CD image #3: CD_Image_File_CD3.bin
    "C:\Program Files\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD3 .cue" --bin-file="C:\PROGRA~1\DVD2SVCD\Movie\CD_Image_File_CD3 .bin" "C:\PROGRA~1\DVD2SVCD\Movie\VCDXBU~3.XML"
    CD-Image creation finished.
    - Free on drive C: 51061.89 mb
    - SVCD Creation finished!
  2. Looks like nobody knows.
    I'll try another time. I'm experimenting anyway.
    I opened DVD2AVI_PROJECT_FILE.d2v in TMPGEnc and it accepted it also for audio I opeded Encoded_audio_1.mp2 and was accepted too. Th only thing I'm wondering is if it's going to fit in 2 cds (VCD) Looking at the audio, the movie looks like it's 2:58:20 minutes.
    Thanks.
