  1. Whenever I try to use MissingMediaBurner to burn the cue/bin generated by MissingMPEGTools, I get an error and the burning is aborted. Here is what happens when I try and burn:
    Using libscg version 'andreas-0.5-UNIXWARE_Patch'
    IOCompactDiscServices: MATSHITA CD-RW CW-7121 Rev: AH36
    Using driver: Generic SCSI-3/MMC - Version 2.0 (options 0x0000)
    Starting write resid: 110
    at speed 2...
    Pausing 10 seconds - hit CTRL-C to abort.
    Process can be aborted with QUIT signal (usually CTRL-\).
    dyld: ./cdrdao Undefined symbols:
    ./cdrdao undefined reference to ___isinfd expected to be defined in /usr/lib/libSystem.B.dylib
    ./cdrdao undefined reference to _pthread_sigmask expected to be defined in /usr/lib/libSystem.B.dylib
    Can anyone tell me what I need to do to fix this problem?
    7th layer of hell
    that doesnt look like the problems i get when burning in cdrdao but i think its possibly different for each burner. open the cue file in text edit and look for the text 'FLAGS DCP' or something along those lines and delete each occurance completely out of the file and save. then feed that cue file into cdrdao and it should work fine from there.
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
  3. I removed the 'FLAGS DCP' from the cue file, and I still get the same error when trying to burn.
