If you do your encoding while you are sleeping or away from home, use this howto to automatically turn off the computer after it's finished encoding.
1. Get CPUsage from http://www.tfm.ro/
2. This free program can automatically shutdown or restart your computer if the CPU usage stays at a certain level for a user defined interval. Since encoding is almost always using the full 100% of the CPU, you can tell it to shut down your machine whenever CPU usage is below 10% for 5 minutes.
Easy!
Although I never turn my box off this is a nice little app.
Thanx
While encoding Xvid or other MP4 video file, PC will shut down suddenly
By StratPlaya in forum Video ConversionReplies: 10Last Post: 14th Feb 2012, 10:10 -
Video length Automatically increase after encoding
By darkstonecold in forum Video ConversionReplies: 1Last Post: 22nd Nov 2011, 21:53 -
Power Shut Down Issue
By Snakebyte1 in forum ComputerReplies: 11Last Post: 6th Dec 2010, 06:50 -
Super converter shut down.
By dfisher052 in forum Video ConversionReplies: 0Last Post: 21st Mar 2009, 09:49 -
Telling McAfee to Shut Up
By ahhaa in forum ComputerReplies: 9Last Post: 23rd Aug 2007, 18:13
