Hi, I'm burning to ISO/UDF, what which ISO mode do I have to use to be compatible with DVD-ROM and with stand alone DVD players???
By mistake the program changes its setting every time. I use NERO.
Does it make any difference if I choose ISO mode 1 or ISO mode 2??
thanks jacob.
I just read the dvd burning guide and it says to use ISO Mode 1.02. So probably you should burn in mode 1 to be compatible with dvdplayers. Take a look at the guide here http://www.vcdhelp.com/nerodvd.htm
We are talking two different things here...
DVD's should ALWAYS be written mode 1, mode 2 uses a slightly longer sector size ( with reduce data checking ) that is only currently appropritate for CD-R type media ( VCD, SVCD, CDDA, ... ).
1.02 is the specification number for the UDF filesystem that is used for DVD-V discs. Their are two formats that are commonly availible 1.02 and 1.05. Unles you want to have compatibility problems ALWAYS USE 1.02
Summary
DVD-Video is ALWAYS mode 1 and UDF 1.02
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 20:13 -
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 22:43 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
