Here at work we just got a Panasonic DMR-HS2 to aid us in our umatic tape backup project. I burned a dvd and it played perfect in the DMR-HS2 player, but once we tried to play them in our Apex 1500 it locks the DVD player down. Our Apex 660 will play them, with the 2x restriction, but it will not display text in the starting menu. So what I was wondering is, what standalone dvd players will play the HS2 burned dvd's perfectly besides the HS2 itself?
I tested it on the following:
Samsung 711: Perfect
All Daewoo Players: Plays, but 2x limited -
Sorry to here about your 1500 because they play fine in my 1500 (SV serial#). I would try another burned disc there since is no reason the 1500 cannot play them. My other findings are as follows:
Apex 1500 (2x restriction)
PS2 (2x restriction)
Toshiba SD1800 (perfectly)
Koss 2165 (perfectly) -
Tried 4 discs. 2 came up with the menu, but locked up upon playing. The other two were DOA.Originally Posted by SergeantD
I have the HS2 and an Apex 1500 (SN A...). My discs created on the HS2 all play fine on my 1500. I purchased some of the 1500s (SN D...) for relatives and found that they would not play my discs from the HS2 until I upgraded the firmware. They all play the discs fine now
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
