I've wasted several blank dvd's so i hope someone can help me. I rip the movies with dvd decrypter , or smartrip, i create the d2v file with dvd2avi, i re-encode with TMpeg, and i author with dvd maestro someone please tell me what i am doing wrong, the chapters work fine and the whole movie is present i just have this weird jitter going on.
Pentium 4 2.53 Ghz, 850EMV2L, 768 MB PC1066 Rambus, GeForce 4 Ti 4600 Leadtek, Soundblaster Audigy Ex, WD 80GB x2, WD 120GB x1, Plexwriter 48X, Pioneer A06 DVD Rom, Toshiba 1612 DVD Rom, Sony DRU 500A DVD Writer. Almost forgot leadtek TV2000XP Deluxe.
Is that Spruce DVD Maestro? If it is there is no need to re-encode just drag your .m2v file and your .ac3 file into the program and author it.
Is the jitter happening when there is a lot of motion onscreen? It sounds like the order of the interlaced fields may have been reversed. I accidently did this using CCE, and the resulting video was jittery whenever the camera moved. Very annoying to watch! Do you know if your d2v file is top or bottom field first?
will DVD2AVI tell us if its top or bottom field ? im having the same problem with The Ninth GateOriginally Posted by Aerohead
To be honest, I haven't used DVD2AVI yet, so I can't answer your question. However, the following link has some good information about determining the field dominance.
http://www.lukesvideo.com/classifyhighres.html
If you have the time, you can always burn to a test DVD-RW the MPEG file re-encoded with the field order swapped to check out whether or not this fixes the problem. I've heard that DVDs can have either field be the dominant field, so it's just something that has to be checked out before encoding.
Good luck!
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 05:35 -
Blu Ray Player won't play some DVD backups
By Turpulus in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Apr 2009, 03:00 -
DVD to Sony Vegas synch / jitter problems
By Mike Toole in forum EditingReplies: 3Last Post: 20th Feb 2008, 00:15 -
DVD Backups play in PC, not dvd players.
By chewbeeb in forum DVD RippingReplies: 7Last Post: 22nd Dec 2007, 02:26 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 03:21
