  1. i am using the DVD2DVDR method for my first back up and every thing is going to as per instructions,i am now on the last stage , but cannot run gear pro dvd!!
    i have downloaded it twice and started to install it but it just says click here to install?? which i do.
    it then starts to unpack files or extract them,then thats it nothing!!
    it has happened on both down loads
    is there any other program(with basic instructions) i can use for the final stage of my first burn??
    any help is well appreciated
    regards
    scott
  2. try using prasi primo or recordnow max
