HELP !
I can't uninstall the CCE 2.5 trial version .
I already erased all the files, and searched for all the versions of CCE in my machine and can not find it anymore, BUT dvd2dvdr (great program ) always find a CCE 2.5 to reencode my film but has a trial version always with the CCE logo !!
How can I uninstal it ??
P.S. yes I'm a morron
I don't have DVD2SVCD in front of me, but one of the tabs shows where your output folder is, as well as the location of CCE or TMPGenc. Click the tab, find the location, go to the location, delete the folder. DVD2SVCD can't use CCE without the executable file/application. Also, if you are using Windows XP, there is a prefetch folder that keeps a lot of temp files. Do a Search for this file "CCTSP" and delete those files that come up. That is the default name for that particular folder of CCE 2.5. This should completely remove it from your system, unless you actually go into the registry, but 1) You shouldn't have to go that route. And 2) That isn't reccomended at all. Good luck
I was talking about dvd2dvdr (do not know if is the same) but in the output folder tab I can't find any of those files !Originally Posted by defense
Anyway a made asearch in "CCTSP" and found were the little bastard was hiden !
I'm gonna give it a try now... THANKS VERY MUCH !!
How is the trial version software automatically disabled?
By coody in forum ComputerReplies: 2Last Post: 25th Nov 2009, 22:35 -
Avid/Pinnacle trial version
By kj1983 in forum EditingReplies: 1Last Post: 28th Sep 2008, 18:31 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 09:25 -
Using ConvertXtoDVD Trial Version and freezing picture
By DJL82 in forum Video ConversionReplies: 6Last Post: 8th Jan 2008, 17:55
