Hi!
1) Can I do a 1:1 copy of a 4,7Gb DVD-Video using MacOSX and the DVD-R writer of the new PowerBook? What software can I use to do this? Is it freeware?
2) Can I split a DVD-Video that contains more than 4,7Gb, to two (or more) 4,7Gb DVD-R?
Thanks 4 your help and sorry for my poor Englishbut I'm italian
See you!
Daniele Esposito.
Use DVD backup1.2 its awesome the way it works (drag and drop) .Most dvds are more than 4.7 gb so you will have to leave out the extras.But some you wont will be able to copy because they have an animated menu(400mb) leaving out the end of the movie
:cry
i heard of osex is good toohavent tried it[/u][/b] -
I like OSEX. Select DVD Folders and extract the DVD using OSEX. Open up Toast, select DVD. Drag the Audio_TS and VIDEO_TS folders into it and enjoy.Originally Posted by DarthEshpo
i have a 4 year old dvd burner that seams to burn a full dvd but the movie
By dr.bling in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Aug 2009, 23:20 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 04:39 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 09:48
but I'm italian
