I Use Tmpeg 2.55 Plus To Encode A DVD D2v And Wave File (DVD TO AVI Files ) But When Like On Grease They Are Dancing At The End It Becomes Very Blocky And Like A Heatwave Effect,It Seems To Be When There Are Lots Of Moving Objects Together Moving Fast.The Rest Of The Movie Seems Fine But Slight Heatwave Effect Around The People In The Film Or The Objects Like A Car ETC,Pleeassse Help
well...did you encode at standard VCD 2.0 specs??? (352x240 & cbr 1150 bitrate)
normally, vcd quality isn't that good..because of the really low bitrate and resolution....however, if you were to change the resolution, bitrate, and/or the encoding method (i.e. cbr vs. vbr), you could get higher quality, but turn it into non-standard xVCD, which obviously will have less dvd player compatibility than standard VCD 2.0
so, there's not much you can do...but,
1) make sure you force film in dvd2avi and encode in tmpgenc as 23.976 fps + 3:2 pulldown
2) make sure you set motion search accuracy to high quality (slow)..do NOT set it any lower than this -
It just the limitations of the VCD format.. it can't handle lots of fast moving stuff on screen without breaking up into blocks.
Try setting Soften Block Noise to 100 in TMPGEnc. It'll make the picture softer but it'll minimize the block noise (well as much as is possible)
I did Ice Age with this setting & it looked watchable even on a 40" rear projection screen... -
Depends... I have yet to see a VCD that is really worth watching... Seen lots of better looking VHS tapes... VCDs are blocky, have you thought about (X)SVCD, CVD...?
Why are my encoded DIVX files coming out blocky and pixelated?
By peggypwr1 in forum Video ConversionReplies: 18Last Post: 31st Jan 2017, 07:18 -
Best way to rip blocky or Compressed Dvd movies?
By Bharathnat in forum DVD RippingReplies: 7Last Post: 4th Nov 2011, 10:55 -
How to rip Bluray encoded in VC-1 and DTS HD
By Victor D in forum Video ConversionReplies: 21Last Post: 1st Oct 2011, 12:44 -
i nee a machine that will rip lots of dvds to hard disc
By steve1033 in forum Newbie / General discussionsReplies: 0Last Post: 30th Jul 2010, 07:56 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 15:43
