Where is the best place to buy dvd-r media in the uk ?? I have seen adverts which quote £0.80 each for 4.7 Gb. Should I avoid these ??
i use the data safe discs from www.bigpockets.co.uk and they're spot on played on every player.they apparently use the same dye as the traxdata discs.they're single speed but outstanding.
I use the Ritek Unbranded silver (by spool) at about 1.29 each, and have never had an error. They are the cheapest I was able to find without errors (I tried 4 or 5 cheap brands)
ZZ -
I mostly use dvd-rw whitelabel from bigpockets.co.uk.
at £8.99 they're cheaper than a lot of the dvd-r & work ok on my sony dvd player. Something to think about
Fakerbaker , do you mean " Whitelabel Colour Top 4.7gb DVD-R " ( blue lables ) @ £5.90 for a pack of 10 ?? or do you mean the gold ones ??
I use blankdiscshop.co.uk for my orders.
They are very cheap, and delivery is very quick.
I just bought these:
NEW FWS BRANDED 4.7GB DVD-R disc (Pack of 25 discs)
The new version of the branded high quality FWS disc.
Has anyone had any experience with them, especially using the sony dru500a, or a pioneer dv350 standalone dvd player.
