  1. Hi!
    I wonder if anyone can help me... Its like this, this saturday i tried for the first time to convert dvd2divx onstead of dvd2vcd. Becose of the time you save. My first went fine but when i tried to convert my second it didnt work... The movie didnt play. So I tired to fix it but nothing worked and i screwed up even mor. Now when you star Flask Mpeg it always stands on 23.... fps when it always have been 25 and you cant say how many seconds it should convert. And the conversions never succed. I tried to reinstall it but that didnt do much good. So I Wonder, is there anyfiles that stores the settings that you can delet so that Flask Mpeg can be like it was the first time I installed it?
    Thanks in a
  2. Or any other advice is very welcomed.
  3. If you are absolutely sure that your material is PAL but FlaskMPEG says it's something else, chances are you didn't rip your material properly (or something screwed up).
    Try ripping it again (e.g., with DVD Decrypter).
    Regards.
    Michael Tam
    w: Morsels of Evidence
