    Dec 2002
    hi m8s i have a big prob i bought spiderman from the woolies and want to make a back up for my 12 year old .i have made 3 backups of others with out any probs but spiderman is give me a massive head ache get sound and coverting all done but when i go to compile it says audio file has an error or corrupt tried 3 diff programs to compile it say same thing tried 3 time to do this a nice 21 hours in total any body had same prob or done spiderman backup successfully
    please help
  2. unfortunately i can't help but i have the same problem with spiderman, it encodes fine but when i go to burn it, it says it is not a valid mpeg file.
    I have tried everyway i can think of to encode it, even did a divx, then to mpeg and still the same problem, though it was a great looking divx!
    Dec 2002
    is there some kind of protection on it do you think?
  4. Originally Posted by jetli68
    please help
    Here is how to do Spiderman:
    1. Smartripper or DVD Decrytper
    2. IfoEdit - VOB EXTRAS to strip off everything except ENGLISH and Dolby Audio.
    3. Exit IfoEdit
    4. IfoEdit and GET VTS_SECTOR to align everything.
    5. burn NERO
    There are plenty of GUIDES on this site to give the details.
    Spider-Man starts off at 5.5GB's. After doing the above process you end up with 4.3GB's which fits on 1 DVDr. I have done this!
  5. i did spiderman last week with no problems at all.
    the film doesnt need re-encoding it will fit on 1 dvdr.
    i use smartripper (ripping just the film) then spruceup to compile.
    then prassi primo dvd to burn.
    thingimijig.
    Dec 2002
    i have got it small enough to fit on 1 dvdr but when go to compile it say error in audio file i will give it another shot tomorrow
    cheers for all your help m8s
    Jul 2002
    New Mexico
    I just got done backing up Spiderman (NTSC, Widescreen) using the method described by joepic. I stripped everything except 6-ch english audio and main movie. It took up every last bit on the disc, but it fit. No transcoding necessary.
