I have just made .m2v file of Star Wars AOTC using CCE method which is about 3.2Gb
My problem is I cannot get it to work with rest of DVD contents
there are 7 original VTS_01_x.VOB files from 0 to 6 on DVD
VTS_01_0.VOB is the menu file and the others 1 to 6 the movie
I have tried using IfoEdit by opening VTS_01_0.IFO and then clicking VOB extras and ticking remux the .m2v file with the stripped audio but it didn't work
It worked OK when I played it back, until around the 2nd minute and thats when the video started to stutter
I also used another method using Author New DVD in IfoEdit and created the new VTS_01_1.VOB,VTS_01_2.VOB, VTS_01_3.VOB,VTS_01_4.VOB files and they work great if I play them with PowerDVD
But how do I get these working VOB's to replace the original ones and retain chapter selection? so I can play DVD exactly like original as when I play back the movie it has all the menus at the end of the movie?
Cheers
Results 1 to 1 of 1
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Most stable, fastest and easy encoder for Windows 7 64 Bit
By pectin232 in forum Video ConversionReplies: 2Last Post: 30th Nov 2010, 06:07 -
How to reduce the bit rate of Blu-ray content on hard drive
By WillN in forum Authoring (Blu-ray)Replies: 4Last Post: 20th Jul 2010, 21:07 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46
