Hi all,
I have downloaded vob trailers from the net. I demuxed them, then used spruce up to author but it can import some of them (not all) because others are ntsc and others pal others ac3 and others dts.
I used ifoedit to create new ifo's from the vob file (which i renamed to vts_01_x and so on) but from 15 trailers i came up with ONLY 3 chapters!!!
MY QUESTION IS: Can anyone tell me the way to create a chapter for each one of the vob trailer in ifoedit?? Like 15 trailers (vob) = 15 chapters.
Thank you in advance
P.S. I tried scenarist & maestro but they are to complicated for me.
Thank you![]()
From Greece
Ok....
When i see a question that i can answer i will answer it or i will try to help the person with the problem.
I made 2-3 posts here in vcdhelp about various matters (easy ones and hard ones) and NOT ONE person has replied....
I thought that this forum was to help each other but i was SOOOO wrong....
For exaple i made a question about something a month ago...123 views and no reply!!!! But in older posts i found that there was a simmilar question and it was answered...so someone knows the answer and is to lazy to answer....
Thank you all for..........hmmm nothing -
1. Please wait some days before bumping your post (reply to your own post).
2.For exaple i made a question about something a month ago...123 views and no reply!!!! But in older posts i found that there was a simmilar question and it was answered...so someone knows the answer and is to lazy to answer....
Have you checked doom9s ifoedit forum? Cause I don't know how to fix it using ifoedit. Maybe if you reauthored it using ifoedit and adding manual chapters. http://www.doom9.org/index.html?/mpg/ifoedit-dvdauthor.htm -
i checked the ENTIRE doom9 forum in ifoedit section and didn't find anything.......
I thought that it was simple.....but i guess not.
I own sonic scenarist & maestro but i think (from what i see in doom9 guide) that i will have to spend much time on it and it's pretty difficult to create the dvd from those programms.
I thought that for every vob file, ifoedit could do the job but...bad luck.
Anyway thank you for your reply ....i guess there is no easy solution to my problem.
Sorry for my poor english (Greece)
Need FREE DVD Authoring Software (Which Authors VOBs & Allows Menus Etc)?
By larrytxeast in forum Authoring (DVD)Replies: 15Last Post: 26th Jul 2010, 13:07 -
Authoring VOBs into Titlesets with Chapters
By matthewjohn23 in forum Authoring (DVD)Replies: 3Last Post: 16th Jan 2010, 14:24 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 11:25 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52
