Can anyone help me.
Ishould burn an minidvd. on cd-r.
with Spruce.
Ihave encode the movie with tmpegenc.
too an *.m2v file and have the sound in an ac3 sound.
then I have multiplex it with bbmpeg.
too an mpeg2 file in dvd format.
then I open Spruce and should add the media file.
it say.
a msg box came up "error system header"
What is the problem.
"I have Try to reencode it meny times but there is the same problem"
On 2001-08-25 12:53:50, MoZo wrote:
Can anyone help me.
with Spruce.
it say.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
hiya..
you dont need to mux with bbmpeg first..just name the m2v and ac3 files the same (i.e movie.m2v and movie.ac3) and put them in the same folder then open the m2v with spruce and it will automatically open both the m2v and ac3 and mux them together.
andydd -
True but...there is no way to corret any sync issues once it is in SpruceUP..well none that I have found anyways..but he is right...dont mux with BBmpeg...just make sure your AC3 file has the same name as your video..ie matrix.m2v, then your AC3 should be matrix.ac3...import the video & then the audio will automatically be imported as well
Does Spruce import more than one ac3 file? Like the 2 and 6 channel streams? What program does the same thing but keeps the 16:9 ratio?
hi, i've just installed spruce, but because i don't have any registration id
and no enablingkey thigs like dolby AC-3 will be left out .
by the way, how long did tempeg take to encode a dvd? -
It was taking about 23 hours and it still had 10 to go before I stopped it. Didn't seem much point in it since I couldn't put it on a DVD!
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 05:10 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
