Hello Everyone:
I've been downloading movies off of one of the popular sites and I get the avi files. I notice that the frame rate is usually around 14. something and when it comes to picking the format such as ntsc or one of the others for encoding those frame rates are 23 or 25. So whenever I encode an avi file to mpeg 1 or 2 and the frame rate is around 14 or 15 do I need to convert it to 23 or 25 for encoding??? If so..why?..
Thanks,
Comet
If you want to make a VCD or a SVCD, then you will need to convert it to MPEG of particular specifications. Among those are specific framerates:
http://www.vcdhelp.com/vcd
http://www.vcdhelp.com/svcd
Regards.Michael Tam
w: Morsels of Evidence -
Hey:
Thanks for the reply Michael. I will read those links thoroughly.
Comet -
If the framerate is nearly 15fps, the original source was probrably NTSC (29.97 fps) and half the frames have been discarded to minimise the file size. Encoding to NTSC will probrably yield the best results, although dont expect too much with only 15fps.
Hey:
Thanks Craig..that was more of the reply that i was looking for..most of the avi files that i've downloaded from kazaa as CD1 and CD2 are like that. Any suggestions on where I could get better ones?
Comet -
This is sailing a bit close to the wind as far as the Warez situation is concerned. Providing you have legal fair use rights to the movie you are downloading, then good quality rips can be found on Kaaza
Hi Craig:
Someone else warned me that this wasn't a topic of discussion on this forum so I will respect that.
Thanks,
comet
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 06:46 -
Of PAL DVDs, .avi files, and frame rates
By AlphaCat in forum Authoring (DVD)Replies: 4Last Post: 30th Jan 2012, 08:23 -
need software to convert video files that have different frame rates
By snafubaby in forum Video ConversionReplies: 2Last Post: 7th Mar 2011, 02:33 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 18:47 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03
