Hallo.
If this is possible, tell me please how to do it.
Why do I need it?
I'm going to send SCVD home video to another country in order to play
it on standalone DVD player there
I would like to send there bin/cue files, but I can't because people, where
I'm going to send it, can burn only *.iso images(( (don't ask me why,
because they didn't tell me
maybe VCDEasy ???
but I don't know how(
greetings
Maciej
Perhaps someone can correctly me on this if I'm mistaken, but I didn't think that an .ISO image would be able to correctly carry all the information required to make the S/VCD (i.e., the multi-mode tracks, etc.)...
If they really can't burn CUE/BIN images (which I doubt very much because you can burn CUE/BIN images on just about EVERY platform), perhaps it would be wiser to simply send the source MPEG file and they use a VCD authoring program on their side..
A way of generating an ISO image from the CUE/BIN image (be warned: I don't know if this will end up with an image of a working disc) would be to mount the CUE/BIN image as a virtual CD with daemon-tools and then use whatever imaging program you normally use to make the ISO.
I don't know enough about CDMage but I have a hunch it may be able to do it as well.
Regards.Michael Tam
w: Morsels of Evidence -
Try downloading winiso for this. www.winiso.com you can open the bin/cue and export it as an iso file. hope this helps... -purp
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
