woohoo! managed to build my first dvd with maestro. thanks to you guys solved the sync probs and various other stuff too.
now, a little thing that bothers me a bit. if i assign targets to the "next" and "previous" sources i can use the next and previous buttons on the powerdvd player to skip from one movie to the other but i cant use the timeline slider anymore.
if i dont assign values to those souces, i can use the slider but cant skip to the next or previous movie with the buttons, rather have to use the numerical pad.
does that have to be this way?
if you have time code embedded into your mpeg file and audio file (audio might not be required but my hardware dolby encoder adds it anyway) and set maestro to asset based time instead of 0 based .. you should be able to use slider and next and prev etc..
i think this is what is required but cant check it out untill tomorow .. -
thanks. i'll try that now.
btw, anyone know where to get or has the dvdmaestro help file or a manual in pdf format? would appreciate it. -
thanks for the link. niiice.
btw, the timeline based (movie) thingy did not work. i still can either jump from chapter to chapter or use the or use the navigational slider on powerdvd, both does not work (based on if i assign a connection or not)
5.1 surround pan/channel assignment in Sony Vegas
By mltwitz in forum AudioReplies: 15Last Post: 13th Dec 2011, 10:44 -
Two internet connections on same PC
By sohaibrazzaq in forum ComputerReplies: 4Last Post: 2nd Jul 2009, 10:17 -
My Computer and internet connections
By CANADASFINEST1 in forum ProgrammingReplies: 1Last Post: 28th Nov 2008, 10:24 -
HDMI connections
By Prot in forum DVB / IPTVReplies: 2Last Post: 20th Feb 2008, 17:06 -
HD connections?
By James in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Nov 2007, 17:02
