Hi,
When adding a media asset in Spruceup, it gets through the video portion ok, but at the very end of the audio file I get the following error:
"The last audio frame is incomplete. Continue parsing will skip this frame and terminate the parsing normally. The stream will then be used with one frame less from now on. Otherwise, abort the parsing to correct the problem. Do you want to continue parsing? (0xc10b0003)"
The source was encoded using TMPGEnc, the audio was encoded with tooLame. I demuxed with TMPG first, and as a second test, I re-encoded just the audio from the original wav file with tooLame and replaced the demuxed mpa with this new one, but I got the same error.
I ended up opting to continue, exported to a title set and burned to a DVD-R. The movie seems to be ok, but does anyone know if this is something to be concerned about? What's the deal with this error?
Thanks!
Results 1 to 1 of 1
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 11:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
