I saw some posts about capturing and codec issue. It will alleays end up with saying that with "every" codec (compressioon/capturing method) you loose quality. Now... I am confused about all this. I alwayss tought that with DV camcorders you don't loose quality at all. So here is example.
1. Shooting video with DV Camcorder = DV codec compression tak place and data are stored compressed on tape.
2. Capturing data from DV Camcoder through FireWire (IEEE-1394) to PC. This should be lossles data trasfer. Only possible issues are if PC can't catch up with data.
3. Editing with software without adding titles or transitions. Simple cutting and joining. Should be lossless since no reencoding is needed.
4. Creating AVI file with same DV codec as it was captured. Losless since it will just join original parts of AVI file.
5. Transfering back to DV Camcorder FireWire (IEEE-1394) to PC. This should be lossles data trasfer. Only possible issues are if PC can't provide continues stream of data.
So am I missing something ? Are my assumptions wrong ?
No that all seems correct to me.
The DV codec itself isn't lossless, in your first point you mention DV codec compression for storing video on tape this is the lossy part.
When you record using your DV camcorder it is compressed using the DV codec, transfering it to your PC incurs no further loss or compression. So this transfering process can be considered lossless. -
Thanks Craig for confirming my assumptions.
And just for fun :
Well... any kind of video storage isn't losless. My eyes can see more then 720 linesOriginally Posted by Craig Tucker
. Not sure about frequency...
The codecs considered "lossless" do a direct transfer of the whole frame. File sizes tend to be huge, and the system must be optimized to prevent dropping frames.
The beauty of DV is that it produces a manageable file size with light compression that only needs re-encoding in sections that get titles, transistions, or other special effects.
what codec should I use for editing camcorder dvd ?
By codemaster in forum EditingReplies: 0Last Post: 25th Dec 2011, 05:34 -
need free program to quickly losless crop an mpeg2 740x480 to 720x480
By wolfdogg in forum Newbie / General discussionsReplies: 5Last Post: 13th May 2011, 17:49 -
camcorder dvd to quicktime avid dv codec
By codemaster in forum EditingReplies: 3Last Post: 17th Dec 2010, 09:45 -
Best Losless Video Codec ?
By vodmare in forum Newbie / General discussionsReplies: 49Last Post: 27th Aug 2010, 11:12 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
