Hello.
I´ve now burned around 20 DVD´s. But the film "From Hell" is making me Problems.
Ripped the film on my harddisk.
Looked with Ifoedit which titles are used to play the main movie.
But now comes the problem.
On the DVD is there is only one VTS where all the titles are included.
How can I know which ones are the ones to delete to make the film fit on one DVD+R.
Thanks for your help.
Sorry for my bad english![]()
Just did this movie the other day,
Do the usual, open up the vobs in DVD2AVI, examine the vob/cell number info on the right hand side of the screen. (You have to turn on the stream info setting). As you move the slider at the bottom of your screen to the right , you will be able to view the movie and all the extra FBI warnings/ trailers etc, just note the VOB IDs when the movie starts, then in IFO edit rip them, create new IFO's, then run IFOupdate to merge the new authored movie back into the original movie so you get a full working menu! All on 1 DVDr. Its a snap (I cut the credits out) to give more room. Good Luck! -
The PCG_1 have always just shown VOB-IDs for the Main movie for
most of the movies I have done, I have not done From Hell yet.
But if it still is a FBI warning in front, the first VOB-ID would probably
be the one to un-check.
I always also check to see if the last VOB-ID is only 10seconds etc
as that is only used as a layer break, and if it is I do not include it.
If the last VOB-ID is around 5 minutes long and the movie is
just a little to big to fit on a dvdr I do not include that one. (end-credits)
how much can you actually fit on a "4.7" GB dvd-R?
By brassguy in forum DVD RippingReplies: 12Last Post: 18th Jan 2012, 13:42 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 14:27 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 21:28 -
Bloody Hell! Look at the copy protection for "Reservation Road"
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2008, 18:04 -
Editing self-owned dvd movies to make "clean versions" for my fam
By nef1l1m in forum EditingReplies: 5Last Post: 1st Aug 2007, 14:00
