How to DVD to DVD-R with ifo edit or ifoupdate ?
Below are the content on the dvd
Ex:
VIDEO_TS.BUP 12'288
VIDEO_TS.IFO 12'288
VIDEO_TS.VOB 333'824
VTS_01_0.BUP 59'392
VTS_01_0.IFO 59'392
VTS_01_0.VOB 8'192
VTS_01_1.VOB 373'643'520 trailer or other
VTS_01_2.VOB 473'631'232 trailer or other
VTS_01_3.VOB 104'785'920 trailer or other
VTS_02_0.BUP 88'064
VTS_02_0.IFO 88'064
VTS_02_0.VOB 59'379'712 main menu
VTS_02_1.VOB 1'073'436'672 main movie
VTS_02_2.VOB 1'073'549'312 main movie
VTS_02_3.VOB 1'073'502'208 main movie
VTS_02_4.VOB 1'073'371'136 main movie
VTS_02_5.VOB 1'073'555'456 main movie
VTS_02_6.VOB 810'952'704 main movie
First i resize the main movie vobs to new vts_02_1.vob to vts_02_4.vob
with audio and text. (and gets 4 new files that are 3.4Gb all together)
But how to keep the other above original menus and extras with ifo edit or ifoupdate ?
If you answer, please keep it very simple cause i´m a newbie.
Thanks goes to all who helps me in this matter.
ok, so if i understand you right you have the movie encoded down to the right size?
if you have DVD Maestro this will work for you
if not sorry
take the .m2v and .ac3 files you ripped and encoded
and load them up in DVDMaestro
also use chapter xtractor to rip the chapters
load all of this in DVDMaestro and compile
then use ifoupdate to align the new VOB's
after that you can burn and everything is perfect as it should be
this works for me
flawlessly
but without DVDMaestro you are out of luck as I have found no other successful way to do it
and as I dont believe in Warez I can't help you there
sorry -
Originally Posted by jarvis1781
Same as when I was trying to convert DivX to DVD. I used about 5 different guides (one step from each). Do you mind to create some simple Step-by-Step guide ? Something like this ...
How to author with menu and chapters without re-encoding ?
+1 audio steam to the DVD with original menu.
By kurochocho in forum Authoring (DVD)Replies: 0Last Post: 12th Jul 2011, 10:48 -
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 08:36 -
Original DVD Menu
By cavusozkan in forum Authoring (DVD)Replies: 8Last Post: 17th Feb 2010, 21:54 -
Remove extras and keep the original menus
By jujuandhuhu in forum DVD RippingReplies: 4Last Post: 7th Mar 2008, 08:55 -
Stripping DVD extras, while retaining menu
By Hurre in forum DVD RippingReplies: 3Last Post: 19th Feb 2008, 10:14
