How can I do this. I just want to divide up the SVCD into chapters so that I can skip around the disk. Thanks.
Hi
The easiest way I found is using VCDEasy for chapters.
It fits in between TMPGE and Nero.
Download and Install VCDEasy. Disregard anything about no ASPI layers for CDRDAO. CDRDAO is the burning program in VCDEASY. Just keep using Nero.
Open VCDEasy, click Add Files and find the MPEG2 file that TMPGE created, set up your chapters (either your own or as they were on the DVD) , click GO.
Open Nero then select File\Burn Image, select the Cue sheet and click Write
With VCDEasy you can even choose how your remote controls the movie.
Any more?
Mp4 (nero) with chapters
By smartel in forum Newbie / General discussionsReplies: 11Last Post: 1st May 2011, 22:50 -
How to auto divide DVD into editable clips?
By yamahaalex37 in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:59 -
how can you divide the screen to two?
By maltesefalconese in forum EditingReplies: 4Last Post: 2nd May 2010, 18:54 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 11:46 -
Chapters using Nero Vision?
By aelfheah in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 11:40
