  1. i use videowave 4 and when i convert from .avi to vcd, the video is fine but when the audio plays back, it "chirps" every couple minutes. this happens on the pc and when i put it in my dvd player. am i doing something wrong when i convert?
  2. Sometimes when you hear "chirping" its a bad frame audio problem.
    Is the problem evident in the original AVI?
    or
    Only after encoding?
    "Today is only yesterdays tomorrow"
  3. it only happens after converting to vcd format, and it happens on all files
  4. Have you tried TMPGE to encode?
    Jul 2002
    Erie, PA United States
    I would have to agree with wee haggis. I never had much success when I used VideoWave in the past. TMPGEnc is definately the best option.
    Warning! I'm baaaaaaaaack
  6. do i have to download that program, and if i do where can i get it from? and is that one easy to use to convert because i'm new to this and thats why i was using videowave cuz it pretty much did all the work for me
  7. ok i found the TMPEng but i'm having a few problems with it. i separated the audio and thats taken care of, but i can't figure out how to make a fullscreen movie into a widescreen one, i read through here and i saw to do the opposite but i want to make do it the other way. one last prob, when i do convert the mpeg vcd version has a line on the top left corner of the screen, any idea what may cause this or how to fix it? thank you for all your help
