I am capturing from VHS tape onto PAL VCD. I can capture at a higher res than needed for VCD but will there be any advantage in quality in doing this?
peejay
VCD for pal is 352x288
However, if you capture at 352x576 you will capture both fields per frame which should result in a better quality picture when you encode to mpeg. This is assuming you are capturing to AVI first and then encoding to mpeg.
Read the high vs low res section on this site.
http://www.lukesvideo.com -
I can't speak for your system but from experience I can say that @ a res of 352x480 (for NTSC) from vhs, I dropped frames like crazy, but when I went up to a res of 480x480: boom no dropped frames at all!!
so just experiment!!"The software said Win XP or better, so I Installed Linux"
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Cap from minidv HD
By bts1018 in forum Capturing and VCRReplies: 5Last Post: 19th Jul 2011, 09:56 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Bitrate Cap on Remuxing?
By Ast0reth in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 08:25 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
