I've looked through the forum, but I've been unable to find anything that is the same as my problem.
I have a DiVX file.
I check for bad frames in vdub, there are none.
It's got VBR audio, so I extract as a WAV.
Using TMPGeNC I then create a 3GB file for burning to DVD, using the WAV as the audio source.
I use Ulead Movie Makes to author menus. THen burn the DVD.
When I play it back, the audio is out of sync by about 3 secs.
I get no errors during any of this.
It doesn't happen to all movies. Changing Lanes is one it has recently happened to.
Any ideas?
Thanks in advance.
Mike
you did not do anything to correct the vbr audio. Before you extract the wav you must correct it. Audio/full processing mode, then audio/conversion/48000, stereo, highquality, 16 bit, then save the wav.
I've redone the mpeg now, making sure that the wav exports as above.
The 3GB mpeg that TMPGeNC spits out is fine. The audio is in sync.
So, it's got to be Ulead DVD movie factory that is causing the problem. Because once I've authored the chapters and made the disc image, when I play it, it is out of sync!
Any ideas?
Mike
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
