    Nov 2002
    OK.. here's the problem. I just bought the mpeg-2 encoder to go with nero and it won't let me encode unless I am burning it to disk immediately afterward. My mpeg-2 trial period on tmpg has expired. There is a mpeg-2 encoder in graphedit but I can't find the right combo of filters to make it work. So how can I make an mpeg-2? I would just use nero but I want to create an image with vcdeasy because it gives you so much more control than nero. Is there any way to use my nero encoder with tmpg? Or..what filters do I need to use in graphedit besides the ones necessary to decode the original file?
    In graphedit I used:
    .avi file-->avi splitter-->PICVideo MJPEG Decompressor-->(next line)
    Smart Tee-->MPEG-2 Encoder-->mpeg 2 muxer-->file writer
    .wav file-->wav parser-->mpeg-1 encoder-->mpeg 2 muxer(same as above)
    (That was the only file I have with no sound and I wanted to add a song)
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you should have spent the 49$ and bought tmpgenc instead ...
