Does anyone know of a *nix solution for DV to MPEG-2 transcoding? I have searched around a bit and I'm getting hints that DV and MPEG-2 are not all that different, and since I'm about to get a Formac Studio, which provides video input in DV format, I'm wondering if there are any available transcoders that would be able to create MPEG-2 streams faster than a full conversion to MPEG-2. My initial investigations suggest that the LSX-MPEG (Ligos software for Windows) can do this if you're running on a PC, and I've located a program called "transcode" which seems to be able to take DV input but yet doesn't seem to be able to output MPEG-2 (it's primarily for transcoding to MPEG-4).
Does anyone have any experience with this? Is it too much to hope for that the Mac standard video input format DV can be reasonably quickly transcoded to MPEG-2? My web searches have not yielded very much information on this, but maybe someone out there has some firsthand knowledge...
Results 1 to 1 of 1
Transcoding miniDV to mpeg 2: Input video is RGB 16-235?
By Sullah in forum Video ConversionReplies: 24Last Post: 3rd Aug 2011, 03:02 -
Help with transcoding mpeg-2 files after using VideoReDo...
By photodent in forum Authoring (Blu-ray)Replies: 3Last Post: 22nd Mar 2010, 19:18 -
Remove certain parts from MPEG-2 [no transcoding]?
By therock003 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 13:49 -
Question about HD MPEG-TS transcoding
By fotty in forum DVB / IPTVReplies: 23Last Post: 4th May 2008, 13:08 -
MPEG-2 to DvD with "minimal" transcoding.
By PuzZLeR in forum Video ConversionReplies: 7Last Post: 19th Jun 2007, 16:41
