Didn't see a forum specific for this so I figured I'd try here.
I recently purchased a couple CD's that came with extra DVD's and would like to rip the Audio files off of the DVD's onto my HD and convert them into an mp3 format and eventually throw them on my iPod.
Only problem is I haven't the slightest clue where to start when ripping DVD audio and converting it into an mp3 format (I assume I'll need to do this). I know I could go in using Line In on my soundcard but I'd have to buy some cables and I'd rather do it this way to save a couple bucks.
Any help?
Okay, I ripped the DVD to HD and it's in .vob form. I tried using DVD2AVI to get the audio into .mp3 form but apparently the version of DVD2AVI that I have doesn't have the same options.
I don't have the "MP3 Compress" option when I pull down that menu (nor the Extract DTS, but that's moot because I don't need it).
Anyone able to help now possibly? -
Just follow the first two steps of the How-To Guides. After that you should have a .wav file of the DVD. Just convert the .wav to .mp3.
"It may not reach the end of the barrel, but it sure wreaks havok on the side!!" -
DVD Rip
DVD (VOB) -> MP3 (selected part only, stress-free)
By Henrik2000 in forum AudioReplies: 15Last Post: 11th Aug 2009, 14:03 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36 -
export audio/mp3 from vob file
By funnybunny in forum Newbie / General discussionsReplies: 8Last Post: 5th Jul 2009, 05:01 -
mp3 bite rate to dvd .vob file
By koskofam in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2008, 11:39 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
