Hello, Does anyone know the language-number association in DVD2AVI program? (e.g. 1 = English, 2 = ? and so on.) Also, is this number association static or relative to DVDs and/or original region code (e.g. will 1 always be English?). What numbers are used for Italian and Spanish?
Thank you.
You should have an info.txt file when you rip the vobs. This will tell you what the various audio streams are. If not, get Ifoedit, and open the ifo file.
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 17:00 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 17:46 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
Help with camcorder selection, please!
By odalager in forum Newbie / General discussionsReplies: 11Last Post: 7th May 2008, 17:38
