  1. Hi, it seems every dvd i try to copy is above 5 gig or goes up to 7 gigs. Is there a way to burn them or chop them into parts? Help please?
  2. Tripps22,
    To my knowledge, not on the Mac YET. On PC, a few solutions:
    1) DVDDecrypter and IfoEdit/vobEdit (all freeware, but the "edit" software is hard to learn)
    2)DVDDecrypter, DVDSPLIT/DVDBURN: Same software as above (same author) although not free ($25 us) but it IS easy. More user friendly/less techie. Few buttons but takes lots of time.
    3) DVDxCopy (321 Studios) expensive ($100), and only works on Windows 2000 and XP, but probably the EASIEST of the three
    I purchased and use option 2. I have option 1, but don't have a month to figure it out. Will someday though. VERY powerful.
    7th layer of hell
    if you dont care to keep all the menus and such u can downsample just the video in afropic and then burn to dvd.
    http://www.anycities.com/user/bilestyle/afropic.html
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
