  1. i have a little problem
    i recently started to rip my own vcds using vcd galaxy.i am using nero 5.9.7 burning software as it uses PHILIPS CDi control program,so that the vcd can be played back on a PHILIPS CDi PLAYER..
    the vcd looks pristine when played,however i do have a small problem.
    when the vcd reaches the end of the disc the cdi player just sits in pause mode,until disc is ejected..
    is there anyway of entering info on the neros interface to allow automatic stop of the player,when reaching the end of the disc..
    can anyone please help with this little problem..
    thanks.
  2. I don't know about Nero, but you can definitely do so with VCDEasy (which will also put the CD-i app onto your VCDs for CD-i player compatibility).
    http://www.vcdeasy.org
    http://www.michaeltam.com/cdi_app.html
    Regards.
    Michael Tam
    w: Morsels of Evidence
