  1. Hi could any members tell me if tit is possible to get black hawk on to one dvd i am new to this and have tried useing the dummys guide on this site but keep on geting a video ts file of over six gig what am i doing wrong.
    also in the guide there are two tpmg templates one for pal and one for ntsc but when i try to download the links are dead!!! can anyone supply them so that i know i have the corect settings in tpmg.
    i have done lord of the rings and this turned out ok useing the same tutorial even thoe it sayes it is a longer movie.
  2. im not an expert, im still learning, but that guide is the one that uses vbr. Could be that the bit rate is too high due to the amount of action scenes??
    try looking at a couple of other guides, or try using the wizard in tmpgenc and setting your own bit rate.
    Dec 2001
    South of Sydney. Aus
    Try this link to a good tmpenc dvd template setup
    http://pwp.netcabo.pt/rmn/TMPGEnc_Template.html
  4. Blackhawk down (NTSC)
    Rip VTS_01_1 to VTS_01_6
    re-encode with 3700 bitrate (constant or 2pass varible)
