First thanks a lot to major for bringing ffmpeg to us - and everything for free.
With a little help I got everything to work on a fresh 10.2 partition.
Overall SVCD quality is excellent - I was always using the preset tab for standard SVCD - but I observed the following quality problem:
every 5 to 10 minutes the picture stands still for a fraction of a second while the sound is perfect (I never had sync problems). This is really annoying and my only real problem with ffmpegx 004d to 004g.
I cross-checked that this is not a problem of my toshiba SD220e-DVD-Player.
Does anybody has this problem and a solution?
OK, found the answer by myself. My Toshiba DVD-Player handles VBR-streams, but seems not to like it on standard SVCDs. The solution: CBR on SVCD or XSVCD as output-profile in ffmpeg. Even when I want to use 2500 kb/s as video-bitrate, I know choose XSVCD in the VCD/SVCD-options tab and everything works fine.
ffmpegX and/or Toast 8 - Loss of video quality in converting to DVD
By bonespur in forum MacReplies: 2Last Post: 9th Mar 2011, 02:52 -
PSP V5.00 Video Specs for FFMPEGX 0.0.9y - Higher Quality?
By boomhaueruk in forum ffmpegX general discussionReplies: 0Last Post: 27th Apr 2009, 12:38 -
ffmpegX problem
By air in forum ffmpegX general discussionReplies: 1Last Post: 7th Nov 2008, 13:17 -
ffmpegx problem
By illuzion13 in forum ffmpegX general discussionReplies: 3Last Post: 9th Jun 2007, 15:34 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 12:04
