I have a DTS and dolby digital track in DVD Maestro. I have also created a menu that allows you to select which one you want. My trouble is the movie plays fine with the dolby digital track, but the dts one is horibbly out of sync. I think the delay should be 1920ms but i have no idea how to set this. The picture looks out of sync by this amount, with the audio occuring first and then the movement of the lips on the video.
Anyone got any ideas on how to bring the dts track back into sync?
Cheers!
BTW is there anyway of previewing changes like that in Maestro without having to re-compile the whole thing?
rhuala -
If you install a Cinemaster software player, you can preview most stuff. I don't know how well it would work for audio synchronization issues, however.
not acurate enough for frame sync (could get you in the ballpark though).. plus i dont think it decodes dts
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
Video/Audio out of sync with dts track
By taraquedo in forum DVD RippingReplies: 0Last Post: 3rd Sep 2010, 03:35 -
DTS Sync Issue
By cg1200 in forum Video ConversionReplies: 28Last Post: 24th Apr 2010, 19:53 -
MKV/DTS video playback out of sync
By johnc10 in forum Software PlayingReplies: 1Last Post: 16th Oct 2009, 15:31 -
MKV with DTS audio sync problem
By WidowMaker in forum AudioReplies: 2Last Post: 14th Oct 2008, 14:10
