The situation is this;
When I transfer video from my dv camcorder (sony trv-320) via the 1394 connection I can't hear any audio when viewing the avi in Windows media player 8. I can use the ATI file viewer and it works fine.
This audio issue also seems to be causing problems with Tmpg, it refuses to load the avi. CCE will load and encode the file, but the resulting mpa file can't be played in wmp either.
Besweet can load and convert the mpa but the resulting wav file won't play in wmp.
If I mux the streams resulting from the cce encode and author using dvdit! the dvd is fine.
I've tried capturing with vegas video, premiere, and scenalyzer in DV-1 and -2, all with the same results. Audio is fine during capture but the resulting avi has no audio in wmp.
I downloaded the codec pack from microsoft and installed it, and installed the nemo codecs (a mistake I think), no go.
This is a problem that just cropped up recently - until now it was working fine. Transfer, double click, watch in wmp.
Any suggestions are greatly appreciated.
Results 1 to 1 of 1
Transfer VHS Audio to Computer
By Justron in forum AudioReplies: 1Last Post: 3rd Feb 2012, 11:51 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
transfer audio from mkv to audio of xvid
By suerpflysocal in forum Video ConversionReplies: 7Last Post: 12th Feb 2009, 08:57 -
AVI audio prob or video
By SilverDales in forum Video ConversionReplies: 8Last Post: 25th Jun 2007, 16:50 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 06:28
