anybody have any experience with this brand? do they usually make coasters, or are they good media?
thanks
900 Mghz AMD Athlon Processor
40 GB 7200 HD
60 GB 7200 HD
384 MB RAM
Windows 2000
48x12x48 Memorex CD-R/CD-RW
ATI Radeon 7500 All-In-Wonder -
I've never heard of "Optimum" brand media, but just the name alone makes me think it's yet another generic brand. I think most of the generic stuff right now is coming from CMC, which is not a very good manufacturer. It's probably acceptable (you can burn a data CD just fine), but not good (VCD/SVCD may or may not work well and don't expect any of them to work for more than 5 years or so).
If it's marked as made in Japan, it's probably good. If it's made in Taiwan, it's probably acceptable. If it's made somewhere else, it's probably bad. Most of the decent media comes out of Japan and Taiwan. -
thanks. i got a 100 of them from staples for Free after the mail in rebate. after i use a couple i give my thoughts.
40 GB 7200 HD
60 GB 7200 HD
384 MB RAM
Windows 2000
Can you tell which manufacturere makes optimum cdrs? COuld you check with a program called cdrid or any software that cheks the cd manufactureer?
Thx
Capturing Video 8 with optimum quality
By bwt in forum Capturing and VCRReplies: 7Last Post: 1st Sep 2011, 22:52 -
Optimum Ripbot settings for HD video quality during conversion
By mario595 in forum Blu-ray RippingReplies: 22Last Post: 12th Apr 2010, 14:28 -
Best way (meaning quality and 700MB size) to convert a DVD to a Xvid?
By riahc3 in forum DVD RippingReplies: 24Last Post: 7th Jun 2009, 17:59 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Ripping a DVD to 700mb and getting the best possible quality ?
By tadrian in forum DVD RippingReplies: 1Last Post: 24th Aug 2008, 05:04
