Guys really need help converting a 1.5g mpeg down to size??
i capture a tv show and i had all the settings wrong
a 1/2 hour tv programme file that is 1.5g
i want to make a vcd from it, but i cannot seem to convert the file with tmpgeit just converts to a standard vcd mpeg file which is agian 1.5gig
i also tried to convert it with nero but the speach is all out
wondered if it is poss to convert it to a standard vcd file size and the reburn?
Kel,
If TMPGenc can open it you and you're sure you're using a VCD template then you should be ending up with a file size of about 300mg for that 1/2 hour program.
I'd double check your template and make sure you're using a VCD template.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
the settings i used were mpeg 1 720 x 480
video brite 9513
audio 224
normally when i capture i can re-encode with tmpge
as i said this time the mpeg is 1.5 gig which has never happened before.
i have tried to re -encode with dvd2Avi but i wont load up correctly -
That bitrate (9513) is the main problem. Try lowering the bitrate to 4500 and your file should be somewhere in the 700-800 range, which is burnable.
Hope That Helps!!!:P
I use 7500 bitrate.
I can convert easily with TMPGenc after.
VCD or SVCD
Fozzee -
i normally use lower settings but for some reason the settings went all to ****, the mpeg is only 35 mins long
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 01:34 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 22:36 -
Converting resolution size
By Illusionist in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2008, 01:38
