Hi , I bought here in germany a Samsung DVD Player , I dont know the actall model # now , but I think , my question is quite generall ! My DVD Player has a Region Free Crack and plays quite good ! Yet I cant see Movies that i Burn on a CD on my Laptop ! I think I can only see DVDs and play Mp3 or normal Music Cds on it ! Is it actually possible to hack it somehow or to install a software on it , sow I can see the Movies I burned ??![]()
I am getting bored of always having to plug my Laptop to the TV just to view those movies I have burned.
Hope someone can help me out here
best Regards from Germany
latino7
just an small update, I have a Samsung DVD/Video-CD/CD DVD 611Originally Posted by latino7
How have you actually burned these movies. Have you authored them as VCD. You cannot just burn an mpeg file onto a data CD and play it in your DVD player, if indeed they are mpeg'sOriginally Posted by latino7
thanks for reading my Post !
I burned the movies as Data , thats true , the problem is that I have the Easy CD Creator Platinum Version , and it only allows me to burn movies to VCDs that are mpeg , yet the movies I download from the internet are most oft the Times .avi ! And to be hones I am not a real computer expert , I found once a software to change mpeg to avi but not the other way round, thats why I always burn them as Data
Could u give me another Tipp , what I can do in this case ?
thanks
ciao ciao -
Check out the guides to the left. This one tells you how to convert .avi, etc. to VCD mpg to be burned by Easy CD Creator or Nero. http://www.vcdhelp.com/tmpgenc.htm
Samsung DVD P230 player gets confused
By ckmoore in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2012, 20:11 -
Samsung HR775 DVD player
By akiskekridis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Mar 2011, 10:03 -
Samsung P-191 DVD player Firmware problem
By stfly in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Jun 2010, 10:17 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
Samsung converting VCR (not DVD) playback problems?
By ecc in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th May 2007, 12:38
