  1. Hi everyone
    I need an information about the following topic.
    I have a lot of VCD (about 1000) and I want to buy a DVD writer so that I can copy all my VCDs on DVDs and reduce the number of stored discs.
    Is there any problem in creating VCDs on a DVD support?
    I've read somewhere, on the net, that I should covert the audio sample frequency to 48 kHz, otherwise I couldn't create my DVD (containing videos in VCD format) and make them work on my stand-alone DVD player.
    Can anybody give me further information?
    Maghis
    Apr 2002
    Ireland
    check out this page for all the info you need:
    http://www.vcdhelp.com/vcddvdr.htm
    Mar 2002
    San Antonio, TX
    You can take a standard Video-CD compliant movie(convert with TMPGE) and load that into DVDit SE and it will do the conversion and authorizing for you. Have done a couple already and came out good. Just use the author guide to the left for DVDit SE and the convert guide for TMPGE.
