Hi folks
I recently installed WinXP. In order to have all codecs installed I got Nimo-Codec-Pack and installed it. Now every time I open a mediafile WMP opens, says it loads the file and then closes without any message. In another post a guy said that he had the same problems and it was the Nimo Codec Pack. Is this true? Did I make something wrong? I used the latest version. Is it possible to uninstall it or just parts of it?
Thanx a lot
Diver
Results 1 to 10 of 10
Welcome - to the real world
i also had problems with the latest version, cannot remember what they were ATM. But i just went back to the previous version.
Thanx for the quick answer.
ist it possible to uninstall the Codec-pack?
DiverWelcome - to the real world -
To uninstall the pack goto the control panel -> Add/Remove Programs. Select the nemo pack & uninstall.
After installing Nimo Pack a couple of weeks ago, I had the same problem with WMP and ATI Multimedia Centre, i.e WMP and ATI MC would shutdown while attempting to open any file (video or Audio). I looked for the answers on the Internet and and found the answers at this at this link :http://www.nwlink.com/~zachd/pss/pss.html.
You do not need to go back to old WMP. Go to this web page, which is all about WMP, and follw the procedures: how to recover WMP after Nimo Pack Install. Do not ever use Nimo Pack again.
Hope this will help -
I keep seeing people reporting problems with the Nimo codec pack. My own experience was that it didn't bother to ask me before replacing codecs I already had installed with older versions. When I uninstalled it, it happily removed every A/V codec on the computer instead of just the ones it had installed.
Is there any good reason at all to use it? Every codec it includes is readily available elsewhere (without the Nimo problems), and most people probably only need a few of them anyway. -
Hi
Thanx at all! I managed the problem! Or better to say I think I managed it.
I uninstalled Nimo (thanks to dmonty) and reinstalled it. AND I found at Nimos page the hint: "WARNING !!!
There is an INCOMPATIBILITY with the "TFM Audio Filter v1.0 beta 7" and the Morgan Multimedia Stream Switcher 0.95, DO NOT Install them together, chose one of them only if needed".
And it seems that this was my fault.
After reinstallation everything worked all right. Every movie and every mp3 plays all right (despite of an THX-avi-trailer whitch stutters, but I donŽt know if this was bevore my "crash").
If this wasnŽt the bug iŽll inform u.
By
@antara
very good site! Perhaps I find some more bugs
I tryed the lasted pack from Nimo and got error (I herd the sound but got no pix), I uninstalled all of nimo, and error remaind. I uninstall Windows mediaplayer 7.0 and reinstall this and no error. (I tested one Harry Potter movie from Kasaa)
Some folks have absolutely no problems with nimo. Others think it better only to install codecs as and when you need them.
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 12:45 -
Win7codecs pack
By jh443 in forum Video ConversionReplies: 1Last Post: 16th Oct 2011, 21:10 -
k-lite mega pack codecs 6.30 problems...
By sgbd in forum Software PlayingReplies: 10Last Post: 2nd Sep 2010, 05:46 -
Verbatim DL 50 pack around $60 at Sam's
By bevills1 in forum MediaReplies: 49Last Post: 16th Feb 2010, 02:32 -
Service pack 2 and codecs
By SIRCOOKS in forum Software PlayingReplies: 2Last Post: 18th Mar 2008, 22:25
