Ok, Im trying to copy a video into a simple MPEG file, so that i can run it inside powerpoint. The thing is when ive copied video's before the displayed video is small. So hopefully a simple question, how do i increase the size of the image and maintain image quality? I know it will increase overall file size, that not a problem, I just dont know which settings to change in the capture process, or even if it needs doing after the capture???
Hope this makes some sense all help gratefully appreciated!
TIA
PS If it helps i use a program called Fast Easy (i think) came with the capture stuff, However already got viruadub if its easier to do with that
What are you capturing from and what are you capturing with (hardware)?
If you want better quality when enlarged, you'll probably have to use higher resolution. -
Im using an external capture thingy called Clipmaster, and im hoping to capture direct from a VCR. ALthough as an update the clipmaster works fine from my camcorder, but wont seem to recognise the VCR signal??
CLCCARD on top right of video.
By sagat93 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 22:53 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
New Desk Top for Video editing
By NP11073 in forum ComputerReplies: 1Last Post: 2nd Nov 2008, 07:17 -
Black bar at the top of video not straight
By ScuderiaF430 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2008, 09:32 -
Cropping top, bottom or sides of video
By drtalk in forum Newbie / General discussionsReplies: 8Last Post: 7th Jul 2007, 15:27
