  1. i have mpeg2 file that i want to burn to a DVD-R how i do that?
    there is a way to shrink the mpeg2 file?
  2. MPEG2 file can be burned like any other file. But, if You want to make disk playable in stand-alone DVD-player, You must author DVD. Read How to ... author ... DVD guides to the left!
  3. thanks, i have tried to author with dvdIt PE that i have ,
    i put an mpeg2 file inside (3GB) but the finale mpeg2 size is bigger!
    i want to put 3gb and no bit more!
  4. Most ppl with files getting bigger, have PCM audio problem. There are cheap (and with full working trials!) programs for DVD authoring with MP2 audio support - Ulead DVD-MovieFactory and more expensive DVD-Workshop. + compleately free and easy to use (but with limited features) IFOedit.
    Mar 2002
    San Antonio, TX
    Under DVDit, the build menu there is one called video (something)(at work, don't remember the name) this allows you to see how large the file is and along with Build DVD folder you can manually set the bit rate so the video will be the size you want.
  6. thank, i have another provlem when i want to build a dvd folder on hd it build but with out the movie!!
