  1. it is good option when your DVD size smaller than 4.7GB?
    it is goos at all?
    Aug 2001
    Finland
    Well, you can always try it with a DVD+RW.
    I did one DVD 2 DVD+RW copy, but not on the fly (so I actually read the DVD image on HD first). The DVD+RW worked ok, so I burned the image onto a DVD-R.
    Nov 2002
    Seattle, WA - USA
    It might work for some titles but I wouldn't think the Macrovision stuff would work. Even when using ISO mode in DVD Decrypter this is usually a factor. It would also depend a lot on your DVD burner drive and whether or not you're using the drives on seperate IDE channels, using SCSI, etc. since DVD drives seem to be pretty finicky about these things and the almighty buffer-underrun.
